Results 1 to 14 of 14
Thread: Stereo Upgrade
    Registered User HSV Senator's Avatar
    1,454
    Question Stereo Upgrade
    I'm looking at a very mild upgrade of the stereo in my 2004 Monaro. I don't want to run aftermarket amps or subs.
    It will consist of an Alpine Head Unit with steering wheel adaptor, 4x45 wrms Alpine KTP-445A "Power Pack" amp, front 6.5" and rear speaker upgrade and Focal Bam Sound Deadening. The rest of the system will be factory standard including rear 6.5" subs in the shelf run off a small factory amp in the boot.
    The factory configuration is causing me grief though. Apparently the front, rear and subs are all 2 ohm speakers wired to present a 4 ohm load to the head unit. I think its the following:
    Front: 2 ohm 6.5" speakers + tweeters = 4 ohm
    Rear: 2 ohm 6.5" speakers + 6.5" subs = 4 ohm
    I assume I need aftermarket 2 ohm speakers front and rear. I can get 2 ohm Focal splits for the front but 2ohm rear speakers to wire with the 2 ohm factory subs are impossible to find it seems. The closest I can find are the following:
    Infinity Kappa 62ix @ 2.7 ohm
    JBL GX602 @ 2.3 ohm
    The JBLs may be USA only too.
    How would the 2.7 ohm speakers work in this configuration? Have I understood the factory fronts properly? Any issues with the Alpine power pack amp and factory amp with this speaker setup? Can anyone foresee any other issues with this configuration ?
    Holden Monaro CV8-R
    Lexus IS250
    Jak Sie Masz! trent from punchy's Avatar
    4,921
    Why not run new wiring?
    www.markpakula.com
    2017 Subaru Impreza Hatch - for the grind
    2015 Cervelo S2 - for the fitness
    2005 Honda Accord Euro - for the wife
    2010 BMW S1000RR - for the sanity
    6,284
    The amp is 4ohm, whats the problem ?
    Toss in the new 4ohm speakers and run some wires to em.
    Some of those that work forces are the same that burn crosses.
    1,454
    I'm not sure I actually understand what you guys are recommending, there's no where to run wires to? Are you picturing a regular amp? Keep in mind It's an Alpine KTP-445A. It's technically 6 speakers to a 4 channel despite the factory amp, the fronts may be able to run @ 4 ohm but the rears can't. It's a weird way Holden have wired this but not unheard of for factory systems.
    Holden Monaro CV8-R
    Lexus IS250
    1,454
    This is the amp:
    http://www.strathfieldcarradios.com....iABEgJ_h_D_BwE
    Everything has been plug and play, exactly what I wanted for ease of install and removal but the way the rear speakers have been wired with the rear subs from factory is a bit painful for going aftermarket. Most just go aftermarket amps but It's not what I want to do.
    Holden Monaro CV8-R
    Lexus IS250
    6,284
    ahh plug and play, I missed that bit.
    337
    I don't see the problem with the fronts? The factory splits present a 4 ohm load to the amplifier, almost all aftermarket splits will do the same.
    It doesn't matter what impedance the individual drivers are, only the combined total (if they are wired together obviously).
    The rears must have a passive crossover between the amp and speakers if they are wired to the same amplifier channel. Replicating that is going to a be a pain I would think.
    I would run the rear 6.5's from the HU and power the subs from an amp. Not that amp though as it has no low pass filter that I can see.
    If you are trying to avoid amps in the boot you could use one of the micro class d amps behind the dash. Like this: http://www.strathfieldcarradios.com....ug-wiring-kit/
    Run fronts from 2 channels, rears off the HU, bridge the other 2 channels for the subs. It's 2 ohm stable also which gives you some flexibility.
    Do you have a wiring diagram for the factory system? I'm interested in how they crossover the rears.
    1,454
    Thanks for the response R31t, the 2 ohm comments for the fronts were due to how the factory wired them, as I said to Fondles I think 4 ohm is probably ok there. Itís the rears that are the issue due to the factory amp/subs.
    There is already the Alpine KTP-445A (Class D mini amp) installed in my car:
    It runs directly off the Alpine HU (Single Din job right now but Iím thinking of upgrading to a touch screen Head Unit after I sort all the speakers). All plug and play.
    I donít know exactly how the factory system is wired and thus unfortunately donít have a wiring diagram, what I listed is just my suspicion Iíve actually got a thread open on the Holden forums asking to confirm my thoughts. I just know that the actual factory speakers are stamped 2 ohm. There seems to be heaps of conflicting information out there on this.
    My thoughts were as long as I put 2 ohm speakers in to match what came out then thereís no problem. Getting the 2 ohm speakers then became the problem!
    Holden Monaro CV8-R
    Lexus IS250
    6,284
    CDT do a 2ohm 6.5" coaxial.
    https://www.cdtaudio.com/coaxials/cl6cx.php
    1,454
    I've not heard of that brand before, will do some research! Thanks!
    Holden Monaro CV8-R
    Lexus IS250
    337
    OK, Got you now.
    I think it's unlikely that the rear speakers and subs are driven off a single channel per side. The factory amp you mention will only be powering the subs.
    Keep in mind going from 2 to 4 ohm impedance isn't going to cause any problems anyway, the amplifier will just be delivering less power. P=V^2/R.
    Going the other way, you need to check the amplifier is 2 ohm stable.
    The only issue I can see is if the rear speakers really are 2 ohm, and your alpine amp isn't 2 ohm stable. But the way I read it this is how you have it hooked up now anyway?
    Summary: Put new 4 ohm speakers in, will be fine.
    1,454
    Quote Originally Posted by R31t View Post
    OK, Got you now.
    From what I've read, the amp only runs the subs, the front and rear speakers are run from the HU but the subs/amp are wired into the rear speakers for both 2 ohm sets of speakers/subs to present a 4 ohm load to the factory head unit. I only have a very basic knowledge of car audio so I'm not sure how that works TBH. Although I think its the same for the Alpine HU I have now, I just used an ISO loom for the Alpine first up, then added the Alpine mini amp also using ISO wiring. So it should run the same way as the factory system.
    Holden Monaro CV8-R
    Lexus IS250
    Registered User Grizzler's Avatar
    Sep 2003
    300
    The speakers I pulled out of mine have 3 ohms printed on them.
    1,454
    Quote Originally Posted by Grizzler View Post
    Interesting. Is your car a Monaro? This is what's in my car:
    Holden Monaro CV8-R
    Lexus IS250
