Results 1 to 22 of 22
Thread: S14 brake upgrade
    Opens ALLMTR's Avatar
    Newcastlish
    23,490
    S14 brake upgrade
    Whatís the new hotness (ie cheapest) brake upgrade for an s14? R32?
    Registered User dougmo's Avatar
    1,468
    R33 GTST bigger rotor than 32gtst (296 vs 280)
    Registered User mad_cow's Avatar
    Aug 2010
    1,216
    Z32 twin turbo. Not sure if they are 280 or 296 tho.
    Registered User THE CHIEF's Avatar
    Nov 2016
    383
    R33 GTST 296mm x 30mm or R34 GTT 310mm x 30mm if you can find a set cheap (will need to drill upright for 14mm bolts for gtt brakes).
    Newcastlish
    23,490
    Are there kits or they just bolt on or ?..
    1,468
    z32 is 280 like 32gtst
    Nov 2016
    383
    Just bolt straight on
    Nov 2016
    383
    Can also just leave the s14 callipers and get dog bone adaptors from gktech and then run a 324mm x 30mm gtr rotor.
    Jan 2018
    Nsw
    45
    z32/r32 same as stock but alloy
    r33 same caliper piston but larger spacing so bigger rotor (296?)
    r34 same piston but lager spacing again (310), need to drill out knuckles to 14 mm from 12 mm. did this before up prices all over shop, i picked up a complete front set for $150 so worth it
    32 GTR similar size to R33 GTS-t but weird thickness so rotors ect way more expensive
    32 Vspec/ 33 GTR Brembo. What i went for mine, bolt on all round, need drum hubs on rear but can use non grt stuff so way more common ( what I went with for current car as bolt on) but price all over shop in alst year with GTR tax
    Evo Brembos ... fronts not too hard with adapters, rears expensive to get working, skyline hubs, adapter brackets, z34 rotors ect
    Infinity calipers , front only I think and way cheaper in America than here
    CVs-t as above, cheap in America, no idea after conversion/ shipping
    Seen one or 2 AMG 8 pot adapters floating around, front only I think
    Newcastlish
    23,490
    Quote Originally Posted by THE CHIEF View Post
    This might be the go. Anyone know if engineers have an issue with dog bones?
    Formerly a stupid_cunt fly510's Avatar
    Jan 2006
    Sydney, now London
    5,937
    r34 Gtt & 310mm rotors all bolt on per the earlier suggestion. Trim the disc backing plate and you're away. no dogbones required.
    Boldy going nowhere rolin7's Avatar
    Mar 2006
    Not Mt Druitt
    1,236
    Not if made out of the right material and no welding, plus the right tensile bolts used.
    Pain is temporary, quitting is forever - Lance Armstrong (drug cheat)
    Newcastlish
    23,490
    Quote Originally Posted by fly510 View Post
    Thatís going to involve research and risk (ie getting sent the right bits and knowing that they arenít) as opposed to clicking on gteckís website
    Jan 2006
    Sydney, now London
    5,937
    so maybe im over thinking it but s14 calipers are cast iron as opposed to the alloy units used on other nissans. I still maintain a bolt on factory option such as r32 GTR (296mm) or r34 GTT is better then dogbone & iron calipers on 324mm rotors.
    if you're clicking a website get yourself some braided lines as well. Made a difference on mine.
    Radelaide
    5,505
    No research required, just buy a caliper and disc from the same skyline and bolt it on. No aftermarket parts required. My old bus had 32r calipers and discs.
    You will also need a bigger skyline master cylinder as the bigger calipers take more fluid to move. I think I had a 33r master and a bolt on stopper brace. Worked well.
    Sent from my VS Commodore eurovox headunit using Tapatalk
    Daily: Honda Civic EK1 Hatch
    Little engine that could. itsnotagsr's Avatar
    At work :(
    18,273
    I'd look to see what has the cheapest good pads. No sense paying GTR tax for marginally bigger disks when GTST brake pads might be heaps cheaper?
    (TM - AVENGE)
    16,340
    The iron calipers will be stiffer (ooo errr missus) and possibly give better pedal feel, but will suck at shedding heat.
    Jan 2018
    Nsw
    45
    32 GTR are similar to 33 GTS-T but the disks are different thicknesses. AS less common the brakes rotors cost more.
    All Nissan non brembo 4 pots use the same pads Just rotors are different and legs/ clearance on the rotor to accomodate.
    Buying from GKtech will probably be more of a hassle, with half the stuff needing modifying or breaking or not being great to begin with, rather than a complete bolt on stuff because nissan were lazy (bar r34 needing to drill out knuckles)
    Nov 2016
    383
    Quote Originally Posted by (Locky) View Post
    A lot of gktech stuff, yes but the calliper adaptors actually fit and work as advertised. Had a set on my r33, did over 20 track days braking from speeds in excess of 240 kph. No dramas with them at all, i didn't die, plus 324mm rotors can be had for as little as $150 brand new.
    As far as engineering, thats a different ball game.
    One street away from Guido's den of sin
    24,326
    Mine are engineered (qld). I have adapters on rear for 300mm disc as well.
    Registered User Staples's Avatar
    Feb 2018
    Perth, Western Australia
    68
    Cheapest and best imo is r33gtst. Bolts right on. Engineer wont bat an eyelid. R34 is larger but more $$ r33 GTSt fits under stock wheels also.
    Mar 2011
    Campbelltown, Sydney, Australia
    665
    Wilwood do a 4 piston kit. Uses factory Hub, just new rotor/caliper/pads etc
