Results 1 to 10 of 10
Thread: Ls ecu with a dry shot
    Opens ALLMTR's Avatar
    Newcastlish
    24,131
    Can a factory LS1 ecu be tuned to compensate for a dry shot of nitrous?
    8,235
    Yes. A mates lsa is tuned like that and that's on earlier ecu as they swapped reluctor wheel and back to cable tb
    Sent from my HTC One M9 using Tapatalk
    8,235
    I think they used open/closed loop tables with an arming switch to change
    windsor nsw
    1,283
    I havenít bothered with a dry one. Years ago there were guys using air temp to enrichen and retard and using the factory shift light output to turn on the gas. I donít get it when you can run a plate behind the throttle and a short bit of hose from the port on the rail
    Shitney
    1,114
    I think EFI Live COS5 had some nitrous shit in it. Will look in the morning.
    Opens GAZ914's Avatar
    1,631
    Hoonboy has a dry setup in his Commodore - C&V tuned it.
    Race Car: VT Commodore (Murray)
    www.vsport.com.au
    18,365
    yes its easy
    Melbourne, S.E. suburbs
    1,463
    Can be done, but as BPM mentioned, the port on the rail is right there to supply fuel. Any reason you want to run a dry shot in particular?
    Jul 2007
    Blackwater, QLD
    1,697
    i thought the main reason for a dry shot was significantly improved fuel distribution?
    Newcastlish
    24,131
    A mate wants to do a hidden kit, itís easier to hide a dry kit
