#1 |
hmmm
Pedal going spongy
On the lancer I have been going to the track and everything has been fine.
Yesterday at QR my brakes started getting spongy towards the end of the 5 lap session so much so that I was double pumping to pull up going down the straight. I checked the pads before going out and they had plenty left in them. Once this occured in the first session I then quickly bled them before the next and still had the same problem. They work fantastically for the first 3-4 laps and then start fading. Running Penrite Sin, QFM A1RM pads and RDA slotted rotors. I did improve my time yesterday by roughly 2 seconds over last time so whether I have found the limits of the above combination could also be causing the issue. Any suggestions for something I should try and what could resolve the issue? Assuming it isnt the booster as it is working fine for the first few laps. Would the fading be due to fluid or pads? Thanks for your assistance. |
#2 | ||
could be wheel bearing too
__________________
Quote:
Quote:
#3 |
needs boost...
+1 probably disc moving enough to knock pads back
__________________
E36 M3 12.92 @ 108.64mph, N/A 3.0L |
#4 |
Boldy going nowhere
What dot level fluid are you running? and what pads?
__________________
Jailbait - Cause the best things in life are illegal. |
#5 |
is stable.....really.
I'd have thought if it were pad knock off that it'd happen at various points throughout the whole lap....not just after 5 laps.
Fluid is boiling perhaps? |
#6 |
happy & go lucky
pics of pads and discs hypo?? any glazing or bluing?
I suspect you've reached the limit of the pads/discs to disipate the heat etc.
__________________
Your pathway forward is an exit doorway 1976 TX Gemini Rally Car- crumpled by me, now bits all over the country 1996 VS commodore ute - for sale when I get to it 1998 VT projectfckinwhooshRallyodore 2006 D40 STX navara TD of 160 km/hr towing |
#7 |
Toldya the brakes were shit on these..
Have you got the cooling vents (slots) in the front of the plastic guard liner? |
#8 |
hmmm
Penrite Sin Brake Fluid
TYPICAL PROPERTIES Equilibrium Reflux Boiling Point (dry), oC 310 Equilibrium Reflux Boiling Point (wet), oC 198 Viscosity, Kinematic, cSt at 100oC 2.6 at -40oC 1650 Colour natural pH 8.6 AFM A1RM Pads Formulation - Cold Friction - High Friction - Temperature (C) A1RM - 0.40 - 0.48 - 0-780 Pictures of pads and rotors forth coming. I did however check and make sure that I had adequate pad before going out. It was about 75%. I have not cut any vents yet in the inner guard. I was hoping to protect them due to prevent the water entering the car when driving. |
#9 |
hmmm
On a positive note I am out braking alot of cars on the circuit so this could also be contributing to my downfall.
#10 |
Generally, spongy pedal is fluid, and decent pedel but car not slowing down is pads.
Strange feeling pedal, but car still stopping can be brake lines. Its possible that your brakes are heating up to much, and this excess heat is being transfered to the fluid. |
#11 |
The vents are cut into the later GSRs and evo 3s. From the factory.
Where the corrugations are on the lower front part of the guard liner, the vents are cut into there. Don't worry about the water. |
#12 |
i think you mean out braking, but youre driving a mitsubishi afterall so its anyones guess
__________________
MW#1! |
#13 |
Title pending
Brakes are past their limit
Time to upgrade if you want to do any more than 3 fast laps in a row Nothing really wrong with what you have its just past its limitations
__________________
Location Perth Western Australia |
#14 |
dattoman, have you had experience with upgrading the brakes on these? What kits are available at what sort of coin?
Stock fronts are the same as a TJ magna. |
#15 |
The Penrite Sin is good fluid, but how old is it? the higher temp fluids are even more hydroscopic than normal brake fluid. age, recent rain and our high humdity might be getting to it. time to try a $35 flush before jumping straight to brake upgrades.
#16 |
can you run ducts to the brakes, like those flexible ducts that mount to the strut or whatever for maximum cooling.
dodgy setup but first pic google pulled up
#17 |
hmmm
#18 |
Title pending
So you have the 2 piston caliper
Not the Magna single pot If its got the 2 pots... go buy some EVO Brembos and bolt on
__________________
#19 | |
hmmm
Quote:
I have already researched this option. Opinions on these? http://www.ksportusa.com/asp/brake_k...roduct_id=bk07 Last edited by Hypo; 10-11-09 at 11:49 AM. |
#20 |
Title pending
If its got 2 pots now... then it should have the same mountings as EVO struts
Why do you say it won't bolt on ? Tried ? We bolted EVO Brembos to a Mirage with the same calipers once no dramas That package looks alot like all those common Chinese ones getting around under about 20 different names Small pistons, not much clamp force , no pad choice locally. Only small... 280mm disc... bout the same as original... just thicker Alot of money for maybe not alot of gain
__________________
#21 | |
hmmm
Quote:
They might however fit a Mirage which is CE shape. Ideally if I have to upgrade the brakes I would like to be able to still run 15 inch rims. Last edited by Hypo; 10-11-09 at 01:12 PM. |
#22 | |
hmmm
Quote:
Can get better pics without wheels on later in the week. |
#23 |
fluid flush ftw
#24 |
Title pending
Excuse my igorance... but there was nothing in any posts to say what model the car was
I'm still dubious on this mount bracket thing
__________________
#25 | |
hmmm
Quote:
Lots of people have tried and this guy succeeded with the plates. Fronts ![]() Rears ![]() Some people have gone the 5 stud conversion with a EVO IV lower control arm and new hubs but this modifies the track and new wheels are required. The issue with fitting rear Brembos is that on the EVOs they have the handbrake in the hub and not part of the caliper so I would be required to adapt or utilise a hydraulic handbrake. |
#26 |
Title pending
Well there you go
I knew about the rears and the handbrake issue... alot of people don't bother with the back so I didn't mention it I should have had a better look at the strut today at my mates place He's fitting some 295x28 2 piece discs and AP calipers to a Mirage atm
__________________
#27 |
That conversion was done by perth brake parts. Really good job IMHO.
#28 |
Title pending
Um
Doubt it They don't have a workshop nor the facility to make a bracket Nor anyone with half a noodle able to design it They would have bought it in from east or contracted it local Unless its one of Brents home jobs Not Goodridge hoses either And looks like a green hat... project Mu maybe PBP might have sold him a set of pads once
__________________
#29 |
hmmm
Would you like to recommend someone in Brisbane I could speak to about getting the calipers fitted. Whatever it is that I purchase.
#30 |
Title pending
I would like to
But the only people I know in QLD are at The Brock Shop and not sure they play with lil cars
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flexible brakelines - how long is too long (pedal feel no good) | C0V3R | General | 25 | 29-09-08 12:41 AM |
| Camira calipers, Hiace drums = spongy | sv_i | Brake Clinic | 11 | 05-10-05 12:14 PM |
| FS Gold Coast - Wilwood pedal box | ROYALBLUE | Cars - General Car Parts For Sale or Wanted | 0 | 08-05-05 03:58 PM |
| Spongy Brakes | Burns | Brake Clinic | 1 | 19-12-04 10:35 AM |
